I need help!
I need help!
Post  liam-mk2driver on Fri Feb 18, 2011 1:13 pm
My mk2 golf is lowered 60mm at the front but at standard height at the back and my 60mm rear lowering springs have just arrived in the post. I really want to fit them but im a student so i can't afford to take it to the garage and i dont have a spring compressor so i cant do it at home.
If anyone who has a spring compressor could help me fit them i will be very gratefull!! I live in brigg btw but i'll drive to wherever you are if you can help. thanks
liam-mk2driver
Newbie
Newbie
Re: I need help!
Post  lewis1641 on Fri Feb 18, 2011 1:37 pm
you can safely do the rears without a spring compressor dude.
Re: I need help!
Post  Lowlifedubber on Fri Feb 18, 2011 2:07 pm
Yeah once you have wound the nut up you lose most of the tension on the spring so just push down the spring and undo the nut that last bit.Will be even easier putting the new springs on.
Build Thread
Lowlifedubber
View user profile http://www.lowlifedubz.com/forums/
Re: I need help!
Post  lewis1641 on Fri Feb 18, 2011 2:28 pm
do you know what you are doing? if you need help i can give you a hand but not this weekend.
Re: I need help!
Post  liam-mk2driver on Fri Feb 18, 2011 2:30 pm
I should be ok to do that myself, never taken a strut apart before but i've done harder things so i should be ok, i just dont want it all to fire off into my face!
liam-mk2driver
Newbie
Newbie
Re: I need help!
Post  Krash on Fri Feb 18, 2011 3:02 pm
i have a set of compressors if you wanna borrow them
Krash
Site Regular
Site Regular
Re: I need help!
Post  caistor_bmx on Fri Feb 18, 2011 3:13 pm
As stated rears are fine with out compressors, just do both sides at once and let the rear beam drop then there will be no tension. Slip the springs on both sides then using a jack in the middle gently lift making sure it goes through your top mounts properly on both sides and slip the cups and nuts on the top. Put wheels back on and drop her down then tighten the top nuts fully Very Happy
caistor_bmx
View user profile http://www.fatalitybmx.com
Re: I need help!
Post  liam-mk2driver on Sat Feb 19, 2011 9:12 am
Cheers for help guys, in the end used jubilee clips to compress the springs to get them off and then my new springs went on and i just squeezed them together to get the top nut on and now my caris finally level!
liam-mk2driver
Newbie
Newbie
Re: I need help!
Post  lewis1641 on Sat Feb 19, 2011 10:04 am
pikey!
lets see some pics
Re: I need help!
Post  liam-mk2driver on Sat Feb 19, 2011 7:23 pm
I will get some pictures taken tomorow, couldn't get any today cause the wheather is shite!
liam-mk2driver
Newbie
Newbie
Re: I need help!
