the rocky and i am me show
Page 4 of 11 Previous  1, 2, 3, 4, 5 ... 9, 10, 11  Next
Re: the rocky and i am me show
Post  roccy on Fri Feb 11, 2011 11:47 pm
keep ur eyes peeled and i'll c if i cn find owt
roccy
Post  i_am_me on Fri Feb 11, 2011 11:51 pm
cool
at least i might have a reliable engine then Laughing
how difficult is it to turbo an 8v gti lol!
i_am_me
Post  roccy on Fri Feb 11, 2011 11:53 pm
nt 2 hard i shunt fink its relatively cheap power if u can live wit turbo lag
roccy
Post  i_am_me on Fri Feb 11, 2011 11:54 pm
nah i would stick with bike carbs,it would be cheaper to do and it is a budget build Laughing
i_am_me
Post  roccy on Fri Feb 11, 2011 11:56 pm
yer bike carbs much cheaper and easier cuz u wunt have to fook about changing compression ratio's or owt that way
roccy
Post  i_am_me on Fri Feb 11, 2011 11:59 pm
what would you say is wrong with an engine if its got low compression in two cylinders.
two are at 12 bar one is at 10bar and the other is at 8 bar.
none of the cylinders lose compression when left but two arent pressurising as much.
the engine seems to run fine though.
i_am_me
Post  roccy on Sat Feb 12, 2011 12:01 am
maybe valves or head gasket wich engine is this on ???
cud be rings but then it wunt hold compression or even build much up in that fact
roccy
Post  i_am_me on Sat Feb 12, 2011 12:03 am
i cant be the head gasket or it would lose pressure over time.
the only thing i could think of is a worn camshaft stopping the valves opening fully?
i_am_me
Post  roccy on Sat Feb 12, 2011 12:04 am
hmmm could be this is it or valve gear being worn
roccy
Post  i_am_me on Sat Feb 12, 2011 12:06 am
could it be the tappits not being full of oil? as they are a bit rattly
i_am_me
Post  roccy on Sat Feb 12, 2011 12:08 am
that shunt effect compresion if tappets arnt ful of oil unless they that badly worn and rlli low but then again u wunt just get worn tappets on 2 cylinderd then the rest being fine its far from uneven wer plus i found this follow the link
http://cgi.ebay.co.uk/VW-GOLF-MK1-SCIROCCO-MK2-1-6-GTI-EG-ENGINE-/260725674708?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cb47612d4
roccy
Post  i_am_me on Sat Feb 12, 2011 12:12 am
i didnt know if they would restrict the valve movement.
could be the valves not closing quickly enough but that wouldnt be a problem at the speed the starter spins the engine.
it cant be damaged rings headgasket or valve seats as it would lose compression slowly.
so the only thing it can be is not drawing enough air into the cylnders for some reason.
i_am_me
Post  roccy on Sat Feb 12, 2011 12:16 am
extremely bad carbon deposits in the head ports but with a skim and a new head gasket and valve seats grinded with the ports cleaned out it should be fine providing the rings are ok
roccy
Post  i_am_me on Sat Feb 12, 2011 12:19 am
but why in only 2 of them?
thats the bit that has me puzzled.
i_am_me
Post  roccy on Sat Feb 12, 2011 12:20 am
hmmm yers me 2 its not even and i know u get un even wear bt no to that extreem usually... what engine is it btw
roccy
Post  i_am_me on Sat Feb 12, 2011 12:21 am
1.8 8v
i_am_me
Post  i_am_me on Sat Feb 12, 2011 12:22 am
the battery going dead wouldnt have helped either though
i_am_me
Post  roccy on Sat Feb 12, 2011 12:24 am
no cus compresion testing an engine with flat battery with ruin the results cus u need it 2 be turning over at the same speed evrytime you test each cylinder plus did he have the throttle fully open for each cylindr test cuz that wud ruin the results if he failed that
roccy
Post  i_am_me on Sat Feb 12, 2011 12:26 am
good point i will find that out tomorro but i have a feeling the throttle wont have been opened fully.
i_am_me
Post  roccy on Sat Feb 12, 2011 12:27 am
y is that then who's the engine off ???
roccy
Post  i_am_me on Sat Feb 12, 2011 12:29 am
because the person doesnt know much about cars so i dont think he would know how to test properly.
i didnt know before you showed me
i_am_me
Post  roccy on Sat Feb 12, 2011 12:31 am
fare nuf then well when u speak to him next if u ask about throttle being fully open when testing and also u wanna ask him if he will test the cylinders that are low on compression again if ther still low then he should wet test the cylinders wich is testing them again with some oil down the bores and if it improves the result then it means its rings
roccy
Post  i_am_me on Sat Feb 12, 2011 12:35 am
it would be obvious if it was the rings.it would lose pressure when you lave the compression tester on and it would burn oil when it was running.
i think it might just be that the throttle wasnt open.
all the cylinders were in the green any way and the engine runs well so i dont think it would be anything serious.
i_am_me
Post  roccy on Sat Feb 12, 2011 12:39 am
tru well if it runs smooth and revs up wilingly then it cant be much rong...
and with a good service and clean up like 're seat valves de-coke head new head gasket' will be able to a few extra ponies hiding in ther Smile
roccy
Post  i_am_me on Sat Feb 12, 2011 12:42 am
would still be looking at £60 to do that but that is with a cambelt change at the same time
i_am_me
