Mk3 Bugdet Brakes
Mk3 Bugdet Brakes
Post  Romeo on Wed Jun 29, 2011 7:59 pm
Hi
Looking at changing my brakes over, the fronts are 256s, so all i was thinking was putting some drilled 256s and a gd set of pads on.
Now the rears are drum, but was thinking of changing to disc, got a rough idea what is needed, but would like to double check with you lot.
Romeo
Newbie
Newbie
Re: Mk3 Bugdet Brakes
Post  i_am_me on Wed Jun 29, 2011 8:04 pm
easiest way would be to steal all the parts off one with discs already on it.
if they are the same as mk2 discs you will need.
stub axles with bolts,calipers with bolts,discs,pads,wheel bearings,hand brake cables,brake bias valve and brake lines.
nice and simple to do.
i_am_me
Post  Becca on Thu Jun 30, 2011 8:49 am
are the drive shafts the same sline sizes on the rear disc models?...
Becca
Just Getting Started
Post  slimg60 on Thu Jun 30, 2011 3:22 pm
Might just be easier to pick up a whole rear beam? at least you'd have everything you needed straight up.
To be honest, I'd stay clear if drilled discs, in my experience all they do is clog full of dust, overheat and warp. Grooved are better.
slimg60
Post  Romeo on Thu Jun 30, 2011 5:54 pm
Had no problem with Drilled on my mk2 golf.
Romeo
Newbie
Newbie
Post  Si_CoupeGT on Thu Jun 30, 2011 7:21 pm
I agree with this, I've seen a few drilled discs crack before, stick with grooved. As for pads see if you can get a set of Mintex 1144's, they're great for road use and can stand up to track punishment as well.
Why do you want to change the rears to discs? Rear brakes do almost nothing on a small car so the drums are perfectly good for road use
Si_CoupeGT
Post  Romeo on Thu Jun 30, 2011 10:48 pm
Rear brake change is just for looks really and twice now since replacing has one side collasped.
Romeo
Newbie
Newbie
Post  Lowlifedubber on Fri Jul 01, 2011 5:50 pm
CHeck out my build thread mate it details what you need for the conversion.Page 2 i think mate. Cool
http://bombercountydubs.makeforum.co.uk/t438-pottermk3-golfnow-fully-resprayed
Build Thread
Lowlifedubber
View user profile http://www.lowlifedubz.com/forums/
