head gasket going :(
Post  6N-Dubber on Wed Jan 19, 2011 7:02 pm
hey i brought my car in 2 college 2 day and looked under the oil cap and there was gunk on its not bad yet so going to replace asap is there anything else i need to get while im replacing it????
6N-Dubber
Re: head gasket going :(
Post  lewis1641 on Wed Jan 19, 2011 7:07 pm
rocker cover gasket, cam belt and tensioner, water pump possibly (or is that off the alternator belt like on the gti?)
and a fast road cam!
Post  caistor_bmx on Wed Jan 19, 2011 7:46 pm
GLOL at the last thing.
caistor_bmx
View user profile http://www.fatalitybmx.com
Post  Krash on Wed Jan 19, 2011 8:06 pm
before you replace it take it on a long run get it nice and warm then check it when your finished if there no or noticeably less chances are its just condensation, cold weather + short journeys make it worse
if its hg they'll be other signs, over heating, oil in the expansion tank, excessive smoke from burning oil if the cars has over heated i would recommend getting the head re skimmed in case the head has distorted from the over heating
Krash
Site Regular
Site Regular
Post  6N-Dubber on Wed Jan 19, 2011 8:17 pm
Well it shows no other signs of HG no over heating or oil in expansion tank but im loosing coolant fast no leaks showing and gunk on oil cap so put 2 and 2 together....
6N-Dubber
Post  DubaHolic on Wed Jan 19, 2011 8:49 pm
How does your rad look?? Is it in good condition? It might only be leaking when the engine is at its optimum temp, this is when the pipes will become soft and cracks open up, plus at this temp 9 out 10 you will be in the car drifting so wont notice until the dash light comes on. Have you started the car and just left it stood still untilt he engie warms up and the rad fan kicks in???? I would do this first and have a look then, also have you checked the end of your exhaust after a long drive to see if there is any excess water/moisture in it???
DubaHolic
Admin
Admin
Post  6N-Dubber on Wed Jan 19, 2011 9:39 pm
Well im going to bring again 2moz so ill get it on ramp and look around it all and ill be going from lincoln to gy so that should be long enough??? and ill try a compression test to see if it leaking... but thanks... if i did have to replace would it be costly??
6N-Dubber
Post  DubaHolic on Wed Jan 19, 2011 10:38 pm
no mate it wont cost a lot, well it really depends on if it is really bad that we need to skim the head etc etc but that isnt a hard job ad wont cost much either. We will have a good look at it 2morrow.
DubaHolic
Admin
Admin
Post  6N-Dubber on Wed Jan 19, 2011 11:04 pm
alright thank you bud Very Happy
6N-Dubber
